IcarusAero223
Aerospace
- Mar 10, 2024
- 10
Hi all, I would appreciate any advice for this little problem I'm having. ![[bigears] [bigears] [bigears]](/data/assets/smilies/bigears.gif)
I'm modelling composite wing thats modelled with surfaces in SW and exported as parasolid into Femap (Photos included).
I organized the model into layers: 1. Skin and 2. Internal (spars and ribs). But when I go and mesh surfaces in certain layers, my mesh gets pulled from the other layer into the current active one.
Example: I mesh all of the skin with different assigned properties, and when I switch the layer to mesh the ribs and spar webs, upon meshing the first surface of the rib/spar, all surrounding skin surface mesh shows up in the 2. Internal layer!. (only mesh of the surfaces that share edges gets pulled)
I tried the Geometry > Surface > NonManifold Add command but it didn't help the problem.
So my question is, how do I keep mesh in it's appropriate layer without it switching layers?
