Tom Connor
Unbalanced force determination around a critical surge relief system has illustrated what I've considered to be unreasonable. I'm interested to discuss this with other SR Engineers that may have faced this issue. The currently designed system sketch is attached. The classical calculations (shown) illustrate an unbalanced force across the relief skid of 60 kips which cannot be mitigated. I feel something is missing in the calculation or I've over complicated the issue. The static load when pressure reaches 180 psi is 44 kips in the pipe segment immediately upstream of the surge valve; the downstream pipe segment has a static pressure of approximately 10 psig; 20" pipe is 0.375 wt.
Tom Connor, PE
Operational Fluid Mechanics
Tom Connor, PE
