Unbraced Length (k) Factor? [for Pile that Supports a Multi Span Bridge Bent with Expan Jt]
Beanbag1
The following scenario and question is for structural engineers who design bridges:
Designing a multi span bridge over a creek, say 12 spans each 40-ft for total 480-ft. Each span substructure is comprised of concrete cap supported on pipe piles. The cap and top of piles is approximately 10-feet above the water and the creek bed (mudline) is 10-feet below the waterline, with pile fixity located approximately 10-feet below the mudline. The superstructure is a concrete deck supported on I-beams that are simply supported on each bent. Each I-beam has a hinge bearing (fixed) at one end and a roller bearing (free to translate longitudinally at one end. There is a concrete abutment at each end of the bridge. One abutment has hinged (fixed) bearings for the I-beams while the other abutment has roller bearings (free to translate longitudinally. Thus each span has fixed-expansion type joint arrangement. I can't seem to dind any design textbooks or examples on this topic, but if the expansion joint at each span is say 1-1/2" wide, can the superstructure be assumed to brace the tops of the bents in the bridge's longitudinal direction when determining the unbraced length of the piles (for bucking analysis)? The resulting k-factor could make a big difference in the buckling analysis of the piles. Are there any good textbooks or design examples that speak to this topic?
Thank you.
