Let's say you have an existing concrete beam, and you attached (1) flitch plate on each side (vertical face) of the beam in order to take the full gravity load on said concrete beam. What do you take as the unbraced length of that plate? The anchors are located at the top 3rd of the plate and are spaced at 12" O.C. along the concrete beam length.
Is the Lb of those plate 12"? I guess it depends on the stiffness of the member on which it is attached, correct?
Replace the concrete beam with a wood beam. Does this now depend on the unbraced length of the wood beam?
