rsbmusicguy
Hey all,
I am dealing with a concrete beam on a building that has some deflection (0.5" > 0.469" per L / 480) at the quarter span of the simply supported beam.
I did my calculations and the maximum deflection calculated of approximately 0.25" at the midspan matched what I measured in the field. Additionally, I confirmed that the member was overstressed in moment and shear so I provided repairs to make the section pass.
Note the stirrup cage is not closed and similar sections are at other locations in the building with no issues. My suspicion is that since the stirrup cage is not close that the rebars have split causing the maximum deflection of 0.5" at the quarter span.
Anybody have recommendations on remediation techniques for a stirrup cage that has slipped? I have used couplers in the past but do not want to start chipping away the concrete to find the stirrups which will compromise the section. The only alternative I am aware of is FRP wrap.
Thanks!
RSB
Thanks!
RSB
