akash ananthaswamy
- Nov 1, 2024
- 1
Hi, We manufacture silicon polymer insulators using transfer injection moulding machine. I am having difficulty in recognizing a problem. During moulding, once in a while I have streaks of uncured rubber of size of runner (3mm) occurs. I tried increasing mould temperature and time. it results in over curing of rubber and loss of elongation and strength. generally the rubber breakdown as soon as it is removed from the mould. I am unable to understand the reason why uncure happens. I though it was airlock due to insufficient vents in mould. so i tried bumping. but still the problem persists. Rubber mixing is not an issue because i have mixed it sufficiently. any tips or suggestion would be very helpfull.
