Ceelo124:
The beam moment passes right through that joint, in the crane rail beam, the stiffer element in that joint, and the most direct load path through that joint. The flg. bolts and the cross beam should be looked at to the extent that, based on their relative stiffness against a loading condition, or compatibility w.r.t. defection and rotation they will try to follow the crane beam in its deflection and curvature. A crane load coming from the left will try to twist the cross beam counter clockwise as it approaches the cross beam; the motion will be all vert. deflection when the crane load is centered under the cross beam; and then the cross beam will be deflected and rotated clockwise as the load continues to the right. It is akin to a two beam grillwork of beams which must remain compatible at their connection point. And, since the cross beam is not very stiff torsionally it goes along with the crane beam curvature, as a function of the flg. stiffness’ and bolted connection stiffness, but does not attract much moment in the process of twisting. The bolts should take something more than the crane load, which is basically the condition when the crane is right under the cross beam.
