Understanding Flow Control Valve's Datasheet
Khan_N
Chemical
AU
I have a question about one of the Calculated variable on the flow control Valve Datasheet.
It is called the "Choke Drop". I would like to know what does it mean and what will happen if this condition is achieved. Please see attached datasheet- Row-22
I have searched google but it takes me to Choked Flow and I believe it is a different parameter.
Thanks in advance.
I've never heard the therm "choke drop", but it sure sounds like a descriptive phrase someone came up with for Xt, which is the minimum pressure drop ratio corresponding to choke flow for that particular valve type. If indeed that's what was intended for that datasheet entry, then I suggest you edit the form and add "(Xt)" after the words "choke drop", so there's no confusion about what is meant.
Could it be a typing mistake? You’d better ask your client for clarification.
We'll never know if we can't see the data sheet....
choke drop - it is pressure drop in control valve up to level and it is equal to choke flow or velocity equal to sonic.
if it happen than no more mass can go through control valve
and other issue is cavitation
