1
- #1
Packermanfan
From my understanding, the Maximum Allowable Pressure cannot be exceeded without some sort of yielding of the materials.
1. Is this interpretation of the MAP true?
2. Can the hydrotest pressure exceed the calculated MAP?
I've found plenty of resources for understanding the MAWP, but very little for understanding the MAP, so any information is appreciated.
If it can, what is the actual highest pressure it could be tested at?
If it can't, does the design need to be changed to allow MAP/1.3 (since hydro pressure is typically MAWP*1.3)?
3. The COMPRESS software I use lists the MAWP and MAP as the same values for a particular design. How is this possible? Does it even make sense?If it can't, does the design need to be changed to allow MAP/1.3 (since hydro pressure is typically MAWP*1.3)?
