Pepwa33
- Dec 5, 2019
- 4
Hi there,
I have a 132/33kV Dyn Transformer (transformer neutral earthed via NER) supplying an Ungrounded Single Wye 8MVAr Cap Bank with a neutral VT (and various other feeders). The Ungrounded Cap Bank has a neutral VT for neutral overvoltage (59N) protection.
I was hoping someone could help me understand the following:
Suppose we have an "A" phase to ground fault on the 33kV bus, we could measure this full neutral voltage displacement across the NER (via bus VTs or a neutral VT across the NER). What I am battling to grasp, is what effect this "A" phase fault has on the Capacitor Bank's neutral voltage. I can appreciate that this "A" phase bus fault will shift the Cap Bank's neutral voltage, but i cant draw this or even picture it - I am confused.
1) Do the Transformer's Neutral voltage and Cap Bank's Neutral voltage differ?
2) Can someone show me how to draw the sequence network for this scenario? How would the ungrounded Cap Bank be drawn in this example?
Thanks in advance.
Thanks in advance.
