delta star distribution transformer(11/.38). the neutral of the transformer star is solidly grounded,
if the system is converted to ungrounded system as the neutral grounding is removed ,then what is effect of that during ph to ground fault Specially on single ph loads (220v) line to neutral for each ph even the faulted ph?
thanks
thanks
