Uniform Slab Thickness post tension slab on ground foundation:
At what cable length should I consider changing from a single pull post tension cable to a double end pull post tension cable?
At what length should I consider changing from a double pull cable to breaking the slab into multiple sections?
Thank you for your feedback.
Rich
Rich
