Curious about how others here might approach this situation. Working on a project with an existing industrial warehouse. We're going to hang some insulated panels from the roof. Clearance between the panels and the roof will vary from just enough to get a hand tool in to about 7ft. No access unless you get on a lift (panels will be about 20ft above the floor). Thought is to post signs saying no storage, just in case somebody gets the idea to stick something up there.
The panels are theoretically capable of supporting a 20psf live load for "storage areas above ceilings" in ASCE 7-16 Table 4.3-1. The roof structure they're hanging from...not so much. Since this is NOT a storage area...what would you all do? "Scuttles, skylight ribs, and accessible ceilings" only calls for a 200lb point load. If this were new construction, I'd go for the 20psf all day for simplicity, resilience, and options for future use. But for a retrofit...I don't want to make them rebuild a perfectly good roof if it isn't absolutely necessary.
I'm leaning toward a worst case 10psf/200lb point load.
