Chumpes
Petroleum
- Feb 23, 2016
- 208
Hello
This is quite nothing, but people around me keep on using the unit "bara" for describing partial pressures.
Even if partial pressure of A can be seen as (mol fraction of A) x (total absolute pressure), i find that expressing partial pressure in bara is not relevant because partial pressure must be expressed in bar. For example, nobody would have the idea of expressing partial pressure in barg !!
In quite the same way, pressure drops have to be expressed in bar, not bara or barg.
Do you find relevant expressing partial pressures in "bara" unit ? isn't the unit "bar" sufficient for expression of partial pressures ? why would people add an "a" to bar to point out that absolute pressure SHOULD be used, when absolute pressure MUST always be used for partial pressures ?
remark : bara, barg and bar can be replaced by psia, psig and psi in the previous text.
