Units Help
NewImhotep
45
Iam trying to export an autocad drawing to another program with rounded units (like 25.897 to be 25.6 ) , I tryied with adjust Decimal Precision but it dose't help.
Any way to figure out this ?
25.897 will not round to 25.6.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
If you click on units Command and use
select only 1 place for the decimal
precision and then use regen,
I think it would round the way you want.
diamondjim
Unfortunately that also dosen't work.
I'm not sure what you mean by exporting to another program but I think the numeric accuracy of the Autocad database will remain unchanged regardless of the precision you select in either the units command or for dimensioning. The precision just effects inquiries and dimensions as far as I know.
-Mike
You could try DXFOUT to an ascii format with a decimal place accuracy of 1... I don't know if it will work well for you (or at all)
____________________
Acad2005, Terramodel
Huh?? I didn't do nuth'n!
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
mrMikee
I mean Importing the DXF file in a FEA programs
I tried with many of them but the problem still the same.
lpseifert
that also doesn't work.
any suggestion will be appreciated.
AhmedR
Have you tried to explode this.
Units command usually works.
I have a guess that if it does
not change, it must be a block
of some sort.
