Unloading in Riks 1
Shahrukh_Islam
9
Hi everyone,
I am trying to analyse a beam by loading it to a certain point using a displacement controlled parameter. In this case I need to know the postbuckling behaviour, so I am using Static Riks. My question is how to unload after a certain point during the application of displacement? Firstly, is it even possible using Riks? Secondly, if it is not possible, then how can I extract the final state data from the results and then input it to create a new model and then unload it?
I really would appreciate the help.
Thanks in Advance!
You can use the restart functionality to add non-Riks step with unloading. This approach is described in the documentation chapter "Unstable Collapse and Postbuckling Analysis", paragraph "Obtaining a Solution at a Particular Load or Displacement Value".
But Riks doesn't allow a step to be added after it has been added. How can I do it? Is there a procedure to do it using scripting? If so, what's the process?
It doesn’t matter for restart. It’s a separate analysis, just continuing from where Riks finished. Check its description in the documentation.
So, there is one issue now. I am trying to do another Riks to unload it but it is not working. How can I do the unload from the previous Riks analysis? I could get the restart out but no step can be added after the Riks? Could you help me out? I am getting this error message!
 https://files.engineering.com/getfile.aspx?folder=273d5bfc-44fe-438f-9dfe-9a19895aec5e&file=Snap.JPG
The second step, added in restart analysis, should be non-Riks step (like general static) to simulate unloading.
Thanks for the advice. I had another question. The CAE interface does not allow me to add another step in the steps menu. So, how can I do it? Does it have to be through scripting?
You can do it outside of Abaqus/CAE, using a new input deck for the second analysis. For example:
Code:
*RESTART, READ
*STEP, NAME=UNLOADING, NLGEOM=YES
*STATIC
*CLOAD, OP=NEW
*END STEP
Do you have a process or a thread or an example? That would be really appreciated. Another thing, so, do I do it using text editor and what files do I modify or alter to do this?
Thanks again for all the help
Any text editor will be fine. You can paste this template and adjust it to your case. Keyword syntax is covered in the Keywords documentation guide.
Create a new file with .inp extension, paste that syntax, modify it accordingly and run the analysis from the command line:
abaqus job=first_job_name oldjob=second_job_name
I am sorry again. But do you have a specific guide to do this step by step? I am new to this process. How do I create the file? Is it using just text editor?
I have tried making a file with the following:
*Restart, read, step=last
** STEP: Unloading
*Step, name=Unloading, nlgeom=YES, inc=100
*Static
** BOUNDARY CONDITIONS from Step-1 remain
*Boundary
Set-9, 1, 1
Set-10, 1, 1
Set-10, 2, 2
Set-10, 3, 3
Set-11, 1, 1
Set-11, 6, 6
Set-12, 1, 1
Set-12, 2, 2
Set-12, 3, 3
Set-12, 5, 5
Set-12, 6, 6
Set-14, 1, 1
** Reverse the displacement for unloading in Set-16
Set-16, 2, 2, -1.5
** OUTPUT REQUESTS
*Restart, write, number interval=1
*Output, field, variable=PRESELECT
*Output, history, variable=PRESELECT
*End Step
This is the original file:
*Imperfection,
file=me8_eig, step=1
2, -0.058
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES, inc=1000
*Static, riks
0.01, 1., 1e-05, 0.1, , Set-11, 2, 1.005
** Name: BC-1 Type: Displacement/Rotation
*Boundary, op=NEW
Set-9, 1, 1
** Name: BC-2 Type: Displacement/Rotation
*Boundary, op=NEW
Set-10, 1, 1
Set-10, 2, 2
Set-10, 3, 3
** Name: BC-3 Type: Displacement/Rotation
*Boundary, op=NEW
Set-11, 1, 1
Set-11, 6, 6
** Name: BC-4 Type: Displacement/Rotation
*Boundary, op=NEW
Set-12, 1, 1
Set-12, 2, 2
Set-12, 3, 3
Set-12, 5, 5
Set-12, 6, 6
** Name: BC-5 Type: Displacement/Rotation
*Boundary, op=NEW
Set-14, 1, 1
** Name: BC-6 Type: Displacement/Rotation
*Boundary, op=NEW
Set-16, 2, 2, 1.5
** OUTPUT REQUESTS
*Restart, write, overlay, frequency=1
** FIELD OUTPUT: F-Output-1
*Output, field
*Node Output, variable=PRESELECT
*Element Output, directions=YES, variable=PRESELECT
1, 2, 3, 4, 5
** HISTORY OUTPUT: H-Output-1
*End Step
Do you think my commands are wrong?
I used this command : abaqus job=Riks_unload oldjob=Riks_4 input=Riks_post.inp
But it says I have syntax error
