ENG2194
- Sep 12, 2019
- 45
I have a flat circular head that is welded with a single bevel grove weld inside the shell about 5" from the end (Sec VIII div 1 UG-34 sketch g). The thickness formula in UG-34 (C.2) references a joint efficiency defined as "joint efficiency, from Table UW-12, of any Category A weld as defined in UW-3(a)". Does this mean i can just choose type 1 and get the efficiency correlating to the NDE chosen? In my mind my scenario is a type 7 category c joint ("flat heads to main shell"). How do i get my joint efficiency?
