MramJ
- Aug 26, 2023
- 4
Hi everyone,
I have a geotechnical report that provided an Ultimate Limit State (ULS) bearing capacity of 2000 kPa for silty sand soils with N-values greater than 50 (reaching about 70 blows per 0.3 m). My question is: Is there an upper limit to the ULS value where a geotech would not consider for soils? I ask this because I’ve noticed that similar or even lower values are typically given for bedrock. For example, according to CEFM guidelines, a preliminary design bearing capacity of around 1000 kPa to 4000 kPa can be used for metamorphic rock (medium to high strength). Does this indicate that there is a practical or theoretical threshold beyond which soil ULS values are not realistic? Could someone please clarify this?
Thank you
Thank you
