Franklin M.
Aerospace
Re : on the cutting parameters page in a planar mill toolpath, USE 2d IPW.
Is there anyone out there that uses this?
Please educate me, as a test I generated an op with a 1.0 cutter, the geometry has internal corners. I then cut the same area with a .5 cutter and turn on "use 2d ipw", there is not apparent affect. If I select the reference tool option the toolpath only cuts the corners.
How do I save a "2d ipw" to use?
Franklin
UG 10,13 & 18
NX 1,2,4,6,11 & 12
NCL502 (yep I love Sequential Mill)
Franklin
UG 10,13 & 18
NX 1,2,4,6,11 & 12
