SofiaB
- Jul 9, 2020
- 27
I am modeling a truss subjected to a vertical displacement(load) in the tip. The problem I'm having is, after a experimental analyses I observed buckling in the chord and a contact between the truss chord and a restraining lateral device That incread the rigidity of the truss( the truss can freely move in vertical direction but in the horizontal it can move only the small gap between truss and constraining device)
In abaqus I used several connectors to represent a non linear spring to try and have the same rigid increace as the real model, but can't seem to achieve that(I used a constrain to associate the center of the chord to it's edges and then in the center aplied the conectors)
Is a connector the best way to represent this? Should I try to build a representation of that device as for exemple a rigid body and then define surface to surface contact?
Any help is very much appreciated
Note: for the buckling representation I have used a horizontal displacement
