Hello, was wondering if I could pass compressed air through a venturi pump to pull floating oil from a tank? If yes, how do I control the eventual mixing of oil with the air from the outlet end?
The requirement is given to me by one of my clients who wants an easy, and low-cost solution to remove 'tramp' oil from their CNC machine coolant tanks. I've drawn a quick sketch to explain the application. Can this work? I am assuming the oil will mix with the air inside the venturi to form a kind of mist?
Any advice would be great. Thanks.
