I received testing results for gyp board sheathing that was done per ASTM E330. The average ultimate load for the system before failure was 117 psf. What safety factors need to be applied to this value to get a pressure that I can apply to my Components and Cladding wind pressure table. The manufacturer does not know and says its code related but I can not find anything specific to this. I'm told it is not the same as a Vult pressure vs a Vasd pressure where you use 60%
Thank you,
Thank you,
