My projects are always on the service/consumer/industrial load end user.
Often I have to run by the utility whether the main transformer I'm procuring is WYE or DELTA, and utilities will give me their preferences / requirements.
Can someone walk me through why a utility would want a WYE on the primary? or why in some cases they would want a DELTA on the primary?
Are there use cases / applications for both?
I'd say 90% of the transformers I've seen are WYE on the primary/utility facing side.
