dik
- Apr 13, 2001
- 26,063
Is there a utility that will modify a set of layer names to another set of layer names.
I have a library of several thousand *.dwg files that use my own layer system that is similar to the AIA system, but with structural emphasis. Our office uses a different layer system and our clients may require details to use their layer system. For many standard details, it's a bit of a pain to convert the drawing layers.
Is it possible to use a text file with
oldname1 >delimiter> newname1
oldname2 >delimiter> newname2
oldnameXX >delimiter> newnameXX
type of conversion?
type of conversion?
