Hi
Is it possible to use MBD (Dimxpert) dimension as driving dimension?
I would like to reduce the time frame between design to drawing.
Present case:
Sketching 2D and constraining with relations and dimension.
Creating 3D feature.
Creating 2D drawing by importing 3D model into 2D drawing template and again dimension the part. If dimension annotations are imported from 3D model, the dimension line attached to the part is not clear (Attached to the center of part. not from edge) or different orientation.
For tolerance analysis: dimension the part with MBD / Dimxpert feature.
Mention the assembly sequence.
Define target to calculate the tolerance analysis.
Expecting feature:
If MBD (Dimxpert) dimension are used as driving dimension, the above said process can be modified as below:
Rough sketching.
Create 3D feature.
Position each feature by dragging (Moving the hole, drag the face / edge). Apply relations to features / surface and MBD dimension.
Import 3D model into 2D drawing template for tradition printout / 3D PDF for MBE concept.
Assembly sequence can be defined during assembly.
Now the tolerance analysis can be done for many targets within a clicks.
Present case:
Expecting feature:
Rough sketching.
Create 3D feature.
