Hello everyone,
In accordance with ASME VIII-1, UW-19(c)(2), for welded stayed constructions involving dimpled plates welded to plain plates, the Maximum Allowable Working Pressure (MAWP) of the dimpled components is determined following the requirements outlined in UG-101.
Referencing U-2(g), it is stipulated that when design rules are absent, mandatory appendix 46, (using FEA), may be employed.
Upon careful consideration of the Code's language, it appears that U-2(g) is applicable only in scenarios where design rules are nonexistent. However, UW-19(c)(2) does provide specific rules for the design of dimpled plate welded to plain plates, directing engineer to utilize a proof test.
The query at hand is whether it is permissible to substitute FEA for the proof test in the specific context of UW-19(c)(2).
