ChiangJaron
Industrial
Dear All,
UW-20.4 (b)(2)(a), there told "where the thickness through the weld throat is less
than the nominal tube thickness t",
My question is what is "thickness through the weld throat" mean ?
If the welding shape is fillet welds only 2 mm leg size and tube thickness is 2.11 mm,
Does thickness through the weld throat less than tube thickness t?
