connery
Think about the crank angle with a v. The second stage is drawing the majority its charge when the first stage is at the end of it exhuast cycle. This will reduce the amount of gas storage in the interconnecting pipe between the cyclinders. Thus such timing can be done with only one offset on the crank shaft.
Hydrae
