I need to vacuum test a WWTP digester tank to 3 inches water column vacuum.
My tank is 82' diameter with a base(irregular sump drains) of 16,200cf, main wall area of 456,807cf and a upper area of ~14356cf.
My problem is im specced 3 inches of water column vacuum, and my tank will be filled to el 112 meaning I have 14356cf of STP air at the top and the rest water.
How much water do I have to pump out to reach the vacuum conditions?
