We have some ball valves that were leak checked during commissioning by shutting the valve (typically with pressure on one or both sides)by depressurizing the cavity and then checking the cavity vent for if either of the seals are allowing gas to leak through. Now assuming the test went fine and no further gas is detected once the cavity has been vented, the valve was then opened again under pressure. My question is, will the valve cavity become pressurized if you open the ball under pressure? And if so, does that mean we should be venting all the cavities again after opening to prevent trapped pressure?
