Sep 6, 2019 #1 adula29 Mechanical Jul 10, 2009 53 0 0 PL Hi, I have a question about type of valve used for drain casing pump. E.g for pump OH2 type on casin drain flange I can instal globe valve ora ball valve. Is there a rule that i must use only globe type valve? Thank you for answer.
Sep 7, 2019 #2 mk3223 Mechanical Feb 4, 2006 1,476 0 0 US Normally, a ball valve or gate valve should be suitable for the pump casing drain and the drain pipe routed to the drain hub. Upvote 0 Downvote
