We are going to install a vapor combustion unit (VCU) for a tank and its loading system. It will be natural draft. Basically a burner at the bottom of a stack. We are having a discussion about whether NFPA 86 or some other NFPA code would cover it. When I look at it, there is a burner inside a tube which would supply confinement so I think it would be. There are others with the opinion it is not covered and therefore does not need the double block and BMS of NFPA 86. Is there any guidance or interpretations by NFPA or others on whether it is or what safety systems are required
