EddyWirbelstrom
- Feb 17, 2002
- 216
ABB variable speed drives type ACS580 with front-end uncontrolled 6 pulse rectifier are supplied via Delta-Wye Ground transformers.
The ABB DriveSize Ver 5.9 software reports triplen and even order harmonic currents injected into the system impedance, on both sides of the Delta-Wye Ground transformer.
How can triplen and even order harmonic currents flow in the system imepdance ?
