We have designed the sprinkler system for a warehouse with 1400 GPM at 123 psi water demand. So due to High fire pump capacity, (Regarding NFPA) Is it permissible to have a variable speed drive for the fire pump? Because if only a limited number of sprinklers are activated, the large pump will not work properly. So it is better for the pump to operate at a slower speed.
