  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Variables???
packmen
77
0
0
BR
Hi people
Can I create Variables to use in equations?
Like
A = 60
B = 20
equation 1.
"D1@LocalLPattern1" x A = "D2@LocalLPattern1"
"D3@LocalLPattern1" X B = "D4@LocalLPattern1"
Emerson Bottero
Curitiba PR
Brazil
Emerson,
Why not just use your predefined numbers?
"D1@LocalLPattern1" x 60 = "D2@LocalLPattern1"
"D3@LocalLPattern1" X 20 = "D4@LocalLPattern1" Scott Baugh, CSWP :)
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
Emerson
you could create a dummy dimension and use this dimension to hold your variable.
I.E if you create a sketch and draw a pair of construction lines 60mm apart and then dimension them you can use the dimension as you variable. Change the dimension and your equations will change.
Kevin
kevin@ketd.co.uk
