Variables
garikke
Computer
What is wrong here?
DECLARE
s_id VARCHAR2(32);
s_id =(select store_id from store where key_store_seqid = '&&storeNumber');
BEGIN
select txorder_id, from txorder where order_number = '&&orderNumber' and store_id = '$s_id';
END;
Not sure if this applies, but i had trouble doing an SQLvar1 = "INSERT INTO tablename1 (field1) VALUES ("'& aspformvar1 &'")"
This shows the syntax i was looking for.
it's the asp var name from a submitted form, inside an & on each side, inside single quotes, inside double quotes.
does this make sense? i'm really glad i got it working!! a friend of mine knew the deal and told me the syntax. thank you jason!
dcp - dcparham@directvinternet.com
One thing that I noticed is that you are declaring s_id as a varchar2 with a length of only 32. You are then trying to build s_id as something a lot bigger than 32 characters.
hi dcparham
the syntax is wrong, you wrote>>
"select txorder_id, from txorder where "
remove comma(,) after "txorder_id," and run it.
bye
