RICH535
- Jun 23, 2007
- 18
I have been given the assignment of finding a replacement varistor in a circuit where it is not used as a protection device. Rather it is being used as a voltage-dependent resistor to start an op-amp oscillator. The varistor is in parallel with an inductor and capacitor and is in series with a fixed resistor of 2.7K ohms. The varistor itself measures 75K ohms out-of-circuit. We used to get the varistor from a company called Kanthal Globar. About the only spec I have on it is that its voltage @ 1 mA is 3.3-4.7V. Is there any thing else I could use as a substitute for the varistor?
