varying the value of the force with the value of inertial load
ziko16
New member
LB
Hello everyone,
I would like to ask if it is possible to create a force that changes with the different values of inertial load. For example, I have a mass of an engine that should vary with the g force, is it possible to input only the mass in kg somehow and while changing the inertial load the corresponding weight will be obtained automatically for each analysis.
Thanks in advance,
Zaki
