Vb api save
TiagoFigueiredo
Industrial
PT
I've made the conection between vb and creo.
Now I need some help to do the following:
1st I need to save the screen image to a file *.png to a file
2nd If I have an assembly oppened, I need to reed the parameters from the activated part. Not the displayed assembly, but the activated part in the assembly.
Any idea of how to do it?
Tiago Figueiredo
Tooling Engineer
Youtube channel:
Found it :)
Code:
Dim asynconn As New pfcls.CCpfcAsyncConnection
        Dim conn As pfcls.IpfcAsyncConnection
        Dim session As pfcls.IpfcBaseSession
        conn = asynconn.Connect("", "", ".", 5)
        session = conn.Session
        model = session.GetActiveModel
        window = session.CurrentWindow
        mdlname = session.GetActiveModel.FileName
        Work_dir = session.GetCurrentDirectory
Dim instructions 'As IpfcRasterImageExportInstructions
        Dim rasterHeight As Double = 2
        Dim rasterWidth As Double = 3.85
        Dim dotsPerInch As Integer
        Dim imageDepth As Integer
        Dim bmpInstrs As IpfcBitmapImageExportInstructions
        Try
            dotsPerInch = EpfcDotsPerInch.EpfcRASTERDPI_100
            imageDepth = EpfcRasterDepth.EpfcRASTERDEPTH_24
            bmpInstrs = (New CCpfcBitmapImageExportInstructions).Create(rasterWidth, rasterHeight)
            instructions = bmpInstrs
            window.ExportRasterImage(Work_dir + Nome_imagem + ".bmp", instructions)
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
        End Try
Tiago Figueiredo
Tooling Engineer
Youtube channel:
