Ehaviv
Computer
- Jul 2, 2003
- 1,012
Hi
This simple vb app(compiled to exe) show a black window.(see picture)
how I can prevent from this window to show.
can someone help
Thank you in advanced.
can someone help
Code:
Imports System.Windows.Forms
Module Module1
Sub Main()
Application.Run(New Form1)
End Sub
End Module
Public Class Form1
Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'Form overrides dispose to clean up the component list.
Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing Then
If Not (components Is Nothing) Then
components.Dispose()
End If
End If
MyBase.Dispose(disposing)
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.IContainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
Friend WithEvents Button1 As System.Windows.Forms.Button
Friend WithEvents RichTextBox1 As System.Windows.Forms.RichTextBox
<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
Me.Button1 = New System.Windows.Forms.Button()
Me.RichTextBox1 = New System.Windows.Forms.RichTextBox()
Me.SuspendLayout()
'Button1
Me.Button1.Location = New System.Drawing.Point(120, 272)
Me.Button1.Name = "Button1"
Me.Button1.TabIndex = 1
Me.Button1.Text = "Button1"
'RichTextBox1
Me.RichTextBox1.Location = New System.Drawing.Point(32, 24)
Me.RichTextBox1.Name = "RichTextBox1"
Me.RichTextBox1.Size = New System.Drawing.Size(264, 232)
Me.RichTextBox1.TabIndex = 2
Me.RichTextBox1.Text = ""
'Form1
Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
Me.ClientSize = New System.Drawing.Size(328, 309)
Me.Controls.AddRange(New System.Windows.Forms.Control() {Me.RichTextBox1, Me.Button1})
Me.Name = "Form1"
Me.Text = "ButtonDemo"
Me.ResumeLayout(False)
End Sub
#End Region
Private Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
MessageBox.Show("clicked")
End Sub
End Class
