Kenja824
Automotive
- Nov 5, 2014
- 949
Cowski had created this code for me. As he mentioned in that thread, the arrows were not connecting to the edge right. I told him what he had was awesome for now and I was hoping in my head I could figure it out from there.
I one time found another code where it created Symbol IDs with balloons (which I needed notes associated to components) but this one the leaders connected perfect.
I saw this as a good challenge for me to try and steal the functions I needed from the Symbol code and use them in cowski's code and see if I could get it working. I have to say, trying this and needing to start from scratch several times, I have learned a lot. I still suck at code but I am understanding it a little more and that was the main focus of trying this myself.
At one point I had the arrows connecting exactly where my cursor picked but not attaching to the edge of the component. Looking at it, I realized I needed to use the "get_position_on_object" function from the other code. Unfortunately that has led me into a corner I cant figure out. A stupid null reference error.
With the understanding I have very little idea what I am doing, I would ask you not to laugh too hard if this code is all screwed up looking. But can someone tell me why I am getting this error on line 55?
Code:
Option Strict Off
Imports System
Imports NXOpen
'Imports NXOpen.UI
Imports NXOpen.UF
Imports NXOpen.Drawings
Imports System.Collections.Generic
Module Module2
Dim ufs As UFSession = UFSession.GetUFSession()
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession
'Dim theUI As UI = UI.GetUI()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim lg As LogFile = theSession.LogFile
Sub Main()
'lg.WriteLine("~~ NXJ label component ~~")
'lg.WriteLine("800c0a41-139c-4682-b37f-cfd398de402c")
'lg.WriteLine(" timestamp: " & Now)
If IsNothing(theSession.Parts.Work) Then
'active part required
lg.WriteLine(" no active part, exiting journal")
Return
End If
lw.Open()
Const undoMarkName As String = "create component labels"
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
Dim myDraftingCurve As Drawings.DraftingCurve = Nothing
Dim myPickPt As Point3d
Dim myView As View = Nothing
Dim obj_coords As Point3d = Nothing '---------------------------------------------------------------------FROM IDSYMBOL
Dim edge1 As DisplayableObject = Nothing '----------------------------------------------------------------FROM IDSYMBOL
Dim view1 As DraftingView = Nothing '---------------------------------------------------------------------FROM IDSYMBOL
Dim cursor As Point3d = Nothing '-------------------------------------------------------------------------FROM IDSYMBOL
Dim vwname As String = Nothing '--------------------------------------------------------------------------FROM IDSYMBOL
' Dim coords As Point3d = Nothing '--------------------------------------------------------------------------FROM IDSYMBOL
While SelectDraftingCurve(edge1, myPickPt, view1) <> Selection.Response.Cancel '-----------------------------
Dim parentCount As Integer
Dim parents() As Tag = Nothing
theUfSession.Draw.AskDraftingCurveParents(myDraftingCurve.Tag, parentCount, parents)
Dim someComp As Assemblies.Component = Nothing
' lw.WriteLine("parent count: " & parentCount.ToString)
'-----------------------------------------------------------------------------------------------------FROM IDSYMBOL
ufs.Ui.AskLastPickedView(vwname)
view1 = CType(workPart.DraftingViews.FindObject(vwname), Drawings.DraftingView)
obj_coords = get_position_on_object(edge1, view1, cursor)
For Each temp As Tag In parents
Dim tempObj As NXObject = Utilities.NXObjectManager.Get(temp)
If tempObj.IsOccurrence Then
'lw.WriteLine("owning component: " & tempObj.OwningComponent.DisplayName)
someComp = tempObj.OwningComponent
Else
'lw.WriteLine("owning part: " & tempObj.OwningPart.Leaf)
End If
Next
If IsNothing(someComp) Then
lw.WriteLine("no component selected")
Return
End If
'select point for label
Dim labelPosition As Point3d = SelectScreenPoint()
'lw.WriteLine("label position: " & labelPosition.ToString)
'UF_DRF_create_label
Dim curLetterPrefs As Annotations.LetteringPreferences = theSession.Parts.Work.Annotations.Preferences.GetLetteringPreferences
Dim userSymbolPreferences1 As Annotations.UserSymbolPreferences
userSymbolPreferences1 = theSession.Parts.Work.Annotations.NewUserSymbolPreferences(Annotations.UserSymbolPreferences.SizeType.ScaleAspectRatio, 1, 1)
Dim curDimPrefs As Annotations.LineAndArrowPreferences = theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences
' AddComponentLabel(someComp, edge1, myView, myPickPt, labelPosition, MakeLabelText(someComp))
AddComponentLabel(someComp, edge1, myView, obj_coords, labelPosition, MakeLabelText(someComp))
End While
lw.Close()
End Sub
Function MapView2Abs(ByVal aView As View, ByVal coords As Point3d)
Dim vmx As Matrix3x3 = aView.Matrix
Dim vw() As Double = {0, 0, 0, vmx.Xx, vmx.Xy, vmx.Xz, vmx.Yx, vmx.Yy, vmx.Yz}
Dim abs() As Double = {0, 0, 0, 1, 0, 0, 0, 1, 0}
Dim mx(11) As Double
Dim irc As Integer
Dim c() As Double = {coords.X, coords.Y, coords.Z}
ufs.Trns.CreateCsysMappingMatrix(vw, abs, mx, irc)
ufs.Trns.MapPosition(c, mx)
MapView2Abs = New Point3d(c(0), c(1), c(2))
End Function
Function MapAbs2View(ByVal aView As View, ByVal coords As Point3d)
Dim irc As Integer
ufs.Trns.CreateCsysMappingMatrix(abs, vw, mx, irc)
MapAbs2View = New Point3d(c(0), c(1), c(2))
End Function
'---------FROM IDSYMBOL
Function get_position_on_object(ByVal obj As DisplayableObject, ByVal aView As View, ByRef coords As Point3d)
Dim guess1 As Double() = New Double(2) {}
Dim pt1 As Double() = New Double(2) {}
Dim pt2 As Double() = New Double(2) {}
Dim min_dist As Double
Dim loc_view As Point3d = MapAbs2View(aView, coords)
Dim sp_view As New Point3d(loc_view.X, loc_view.Y, loc_view.Z + 1000)
Dim ep_view As New Point3d(loc_view.X, loc_view.Y, loc_view.Z - 1000)
Dim sp_abs As Point3d = MapView2Abs(aView, sp_view)
Dim ep_abs As Point3d = MapView2Abs(aView, ep_view)
Dim line1 As Line = theSession.Parts.Work.Curves.CreateLine(sp_abs, ep_abs)
line1.SetVisibility(NXOpen.SmartObject.VisibilityOption.Visible)
line1.RedisplayObject()
ufs.Modl.AskMinimumDist(obj.Tag, line1.Tag, 0, guess1, 0, guess1, min_dist, pt1, pt2)
Dim markId2 As Session.UndoMarkId = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete")
theSession.UpdateManager.AddToDeleteList(line1)
theSession.UpdateManager.DoUpdate(markId2)
get_position_on_object = New Point3d(pt1(0), pt1(1), pt1(2))
End Function
Function SelectDraftingCurve(ByRef theDraftingCurve As Drawings.DraftingCurve,
ByRef pickPt As Point3d,
ByRef selView As View) As Selection.Response
Dim message As String = "Drafting Curve:"
Dim title As String = "Select a drafting curve"
Dim scope As Integer = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
Dim response As Integer
Dim draftingCurveTag As Tag = Tag.Null
Dim view As NXOpen.Tag
Dim cursor(2) As Double
Dim ip As UFUi.SelInitFnT = AddressOf mask_for_curves
Dim cursorView As Integer
theUfSession.Ui.AskCursorView(cursorView)
theUfSession.Ui.SetCursorView(0)
theUfSession.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
Try
theUfSession.Ui.SelectWithSingleDialog(message, title, scope, ip,
Nothing, response, draftingCurveTag, cursor, view)
theDraftingCurve = Utilities.NXObjectManager.Get(draftingCurveTag)
selView = Utilities.NXObjectManager.Get(view)
pickPt.X = cursor(0)
pickPt.Y = cursor(1)
pickPt.Z = cursor(2)
If draftingCurveTag <> Tag.Null Then
theUfSession.Disp.SetHighlight(draftingCurveTag, 0)
End If
Finally
theUfSession.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
theUfSession.Ui.SetCursorView(cursorView)
End Try
If response <> UFConstants.UF_UI_OBJECT_SELECTED And
response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
Return Selection.Response.Cancel
Else
Return Selection.Response.Ok
End If
End Function
Function mask_for_curves(ByVal select_ As IntPtr, ByVal userdata As IntPtr) As Integer
Dim num_triples As Integer = 4
Dim mask_triples(3) As UFUi.Mask
mask_triples(0).object_type = UFConstants.UF_line_type
mask_triples(0).object_subtype = 0
mask_triples(0).solid_type = 0
mask_triples(1).object_type = UFConstants.UF_circle_type
mask_triples(1).object_subtype = 0
mask_triples(1).solid_type = 0
mask_triples(2).object_type = UFConstants.UF_conic_type
mask_triples(2).object_subtype = 0
mask_triples(2).solid_type = 0
mask_triples(3).object_type = UFConstants.UF_spline_type
mask_triples(3).object_subtype = 0
mask_triples(3).solid_type = 0
theUfSession.Ui.SetSelMask(select_,
UFUi.SelMaskAction.SelMaskClearAndEnableSpecific,
num_triples, mask_triples)
Return UFConstants.UF_UI_SEL_SUCCESS
End Function
Function GetComponentAttribute(ByVal theComp As Assemblies.Component, ByVal attributeTitle As String) As String
If theComp.HasUserAttribute(attributeTitle, NXObject.AttributeType.String, -1) Then
Return theComp.GetUserAttributeAsString(attributeTitle, NXObject.AttributeType.String, -1)
Else
Return Nothing
End If
End Function
Function SelectScreenPoint() As Point3d
'Allow user to interactively pick the point where the annotation
'will be placed.
'This Function needs Sub MotionCallback() to work properly.
Dim myScreenPos(2) As Double
Dim theViewTag As Tag = theSession.Parts.Display.Views.WorkView.Tag
Dim theResponse As Integer
theUfSession.Ui.SpecifyScreenPosition("pick a point", AddressOf MotionCallback, Nothing, myScreenPos, theViewTag, theResponse)
If theResponse = UFConstants.UF_UI_PICK_RESPONSE Then
Return New Point3d(myScreenPos(0), myScreenPos(1), myScreenPos(2))
Else
Return Nothing
End If
End Function
Sub MotionCallback(ByVal pos() As Double,
ByRef motion_cb_data As UFUi.MotionCbData,
ByVal client_data As System.IntPtr)
'This sub will be called every time a cursor move is detected during the
'SpecifyScreenPosition function.
'The parameters motion_cb_data and client_data are not used in this implementation,
'but the Sub must have the same signature as UFUI.MotionFnT to work properly.
'disable (for now)
Return
Dim wView As NXOpen.View = theSession.Parts.Display.Views.WorkView
Dim topLeft(2) As Double
Dim topRight(2) As Double
Dim botLeft(2) As Double
Dim botRight(2) As Double
Dim labelWidth As Double = 20
Dim labelHeight As Double = 5
'draw rectangle(s) to represent tabular note boundary
Select Case 1
Case Is = 1 'top left
'draw rectangle to the right and down
'pos = top left corner
topLeft(0) = pos(0)
topLeft(1) = pos(1)
topRight(0) = pos(0) + labelWidth
topRight(1) = pos(1)
botLeft(0) = pos(0)
botLeft(1) = pos(1) - labelHeight
botRight(0) = topRight(0)
botRight(1) = botLeft(1)
Case Is = 2 'top right
'draw rectangle to the left and down
'pos = top right corner
topLeft(0) = topRight(0) - labelWidth
topLeft(1) = topRight(1)
botLeft(0) = topLeft(0)
botLeft(1) = topLeft(1) - labelHeight
Case Else 'shouldn't happen
End Select
'for other temp graphics commands, see:
' DisplayOgpArc
' DisplayOgpCircle
' DisplayOgpLine
' DisplayOgpPolyline
theUfSession.Disp.DisplayOgpLine(wView.Tag, topLeft, topRight)
theUfSession.Disp.DisplayOgpLine(wView.Tag, topLeft, botLeft)
theUfSession.Disp.DisplayOgpLine(wView.Tag, botLeft, botRight)
theUfSession.Disp.DisplayOgpLine(wView.Tag, topRight, botRight)
End Sub
Sub AddComponentLabel(ByVal theComponent As Assemblies.Component,
ByVal theDraftingCurve As Drawings.DraftingCurve,
ByVal theView As View,
ByVal leaderPt As Point3d,
ByVal originPt As Point3d,
ByVal theText() As String)
Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Note")
Dim nullNXOpen_Annotations_SimpleDraftingAid As NXOpen.Annotations.SimpleDraftingAid = Nothing
Dim draftingNoteBuilder1 As NXOpen.Annotations.DraftingNoteBuilder = Nothing
draftingNoteBuilder1 = workPart.Annotations.CreateDraftingNoteBuilder(nullNXOpen_Annotations_SimpleDraftingAid)
draftingNoteBuilder1.Origin.Anchor = NXOpen.Annotations.OriginBuilder.AlignmentPosition.MidCenter
draftingNoteBuilder1.Origin.Plane.PlaneMethod = NXOpen.Annotations.PlaneBuilder.PlaneMethodType.XyPlane
Dim leaderData1 As NXOpen.Annotations.LeaderData = Nothing
leaderData1 = workPart.Annotations.CreateLeaderData()
leaderData1.StubSize = theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences.StubLength
'leaderData1.Arrowhead = theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences.FirstArrowType
'lw.WriteLine("first arrow type: " & theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences.FirstArrowType.ToString)
leaderData1.VerticalAttachment = NXOpen.Annotations.LeaderVerticalAttachment.Center
leaderData1.StubSide = NXOpen.Annotations.LeaderSide.Inferred
leaderData1.Arrowhead = NXOpen.Annotations.LeaderData.ArrowheadType.ClosedArrow
draftingNoteBuilder1.Leader.Leaders.Append(leaderData1)
draftingNoteBuilder1.Text.TextBlock.SetText(theText)
' Jog position relocated or jog removed
leaderData1.Jogs.Clear()
Dim assocOrigin1 As NXOpen.Annotations.Annotation.AssociativeOriginData = Nothing
assocOrigin1.OriginType = NXOpen.Annotations.AssociativeOriginType.Drag
Dim nullNXOpen_View As NXOpen.View = Nothing
draftingNoteBuilder1.Origin.SetAssociativeOrigin(assocOrigin1)
draftingNoteBuilder1.Origin.Origin.SetValue(Nothing, nullNXOpen_View, originPt)
draftingNoteBuilder1.Origin.SetInferRelativeToGeometry(False)
leaderData1.Leader.SetValue(theDraftingCurve, theView, leaderPt)
Dim nXObject1 As NXOpen.NXObject = Nothing
nXObject1 = draftingNoteBuilder1.Commit()
draftingNoteBuilder1.Destroy()
End Sub
Function MakeLabelText(ByVal theComponent As Assemblies.Component) As String()
Dim labelText As New List(Of String)
If theComponent.HasUserAttribute("TOOL_ID", NXObject.AttributeType.String, -1) Then
Dim associativeText1 As Annotations.AssociativeText
associativeText1 = workPart.Annotations.CreateAssociativeText()
labelText.Add(associativeText1.GetObjectAttributeText(theComponent, "TOOL_ID"))
associativeText1.Dispose()
End If
If GetComponentAttribute(theComponent, "TOOL_CLASS").ToUpper = "COMM" Then
labelText.Add(associativeText1.GetObjectAttributeText(theComponent, "DB_PART_NAME"))
End If
Return labelText.ToArray
End Function
Function MeasureNoteLength(ByVal theNote As Annotations.Note) As Double
Dim tempLetteringPref As Annotations.LetteringPreferences
tempLetteringPref = theNote.GetLetteringPreferences
tempLetteringPref.AlignmentPosition = Annotations.AlignmentPosition.MidLeft
theNote.SetLetteringPreferences(tempLetteringPref)
Dim noteStart As Point3d = theNote.AnnotationOrigin
tempLetteringPref.AlignmentPosition = Annotations.AlignmentPosition.MidRight
Dim noteEnd As Point3d = theNote.AnnotationOrigin
Return noteEnd.X - noteStart.X
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = Session.LibraryUnloadOption.Immediately
End Function
End Module
