VBA Combobox Multiple Cases
jzecha
Aerospace
I am trying to write a code to automate inserting hole and I am struggling to get part of my code to work.
I have a section of my code that lets you pick between Simple, Counterbored, and Countersunk holes and lets you put the needed information in.
I have gotten the Simple and Counterbored holes to work perfectly, but the issue is there are three different Countersunk hole styles.
So I tired using the same type of code to allow me to pick between those three styles as well inside the code of the Countersunk hole selection, but it fails.
For reference this section of the code is in a VBA Form:
Code:
index5 = cmbobxHoleType.Value
Select Case index5
Case Is = "Simple"
Case Is = "Counterbored"
hDiameter2MM = frmHoleMenu.txtbxDiameter2.Value
hDepth2MM = frmHoleMenu.txtbxDepth2.Value
Case Is = "Countersunk"
    index6 = cmbobx_CS_Typee.Value
    Select Case index6
    Case Is = "Depth & Angle"
    hAngle2 = frmHoleMenu.txtbxAngle2.Value
    Case Is = "Depth & Diameter"
    Case Is = "Angle & Diameter"
    End Select
And this section is in the VBA Module:
Code:
'Setting Up Hole Type (Simple, Tapered, Counterbored...)
Select Case index5
Case Is = "Simple"
oHole.Type = catSimpleHole
oHole.Type = catCounterboredHole
'Dim oHeadDiameter As Length
Set oHeadDiameter = oHole.HeadDiameter
oHeadDiameter.Value = hDiameter2IN
'Dim oHeadDepth As Length
Set oHeadDepth = oHole.HeadDepth
oHeadDepth.Value = hDepth2IN
oPart.UpdateObject oHole
        Select Case index6
        oHole.Type = catCountersunkHole
        oHole.CounterSunkMode = catCSModeDepthAngle
        'Dim oHeadAngle As Angle
        Set oHeadAngle = oHole.HeadAngle
        oHeadAngle.Value = hAngle2IN
        oHole.CounterSunkMode = catCSModeDepthDiameter
        oHole.CounterSunkMode = catCSModeAngleDiameter
        End Select
I've solved a lot of these types of problems by just recording a simple sequence and investigating the resulting code.
That's partially how I got to this area.
I know the variables and how to set them are correct for the features.
I just don't know the best way to use multiple combo boxes in my form for the Countersunk holes.
It's more a question of how to correctly do an Index Case inside an existing Index Case in the code.
Or if this isn't possible, let me know how to handle it better
