VBA Error : Extraction front view with reference to axis system and its plane.
ashish02112
Automotive
Sep 27, 2018
6
IN
I am recording a macro but facing an issue while running it.
I created an axis system in 3D.
And now I am extracting a front view by first selecting the axis and then its plane so that UCS of that view will be that axis.
but after recording and running the same program again it is showing an error.
below is the script.
Sub CATMain()
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.Add("AutomaticNaming")
Dim drawingViewGenerativeLinks1 As DrawingViewGenerativeLinks
Set drawingViewGenerativeLinks1 = drawingView1.GenerativeLinks
Dim drawingViewGenerativeBehavior1 As DrawingViewGenerativeBehavior
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim partDocument1 As PartDocument
Set partDocument1 = documents1.Item("Part1.CATPart")
Dim product1 As Product
Set product1 = partDocument1.GetItem("Part1")
drawingViewGenerativeBehavior1.Document = product1
Dim axisSystem1 As AxisSystem
' No resolution found for the object axisSystem1...
drawingViewGenerativeBehavior1.SetAxisSysteme Nothing, axisSystem1
drawingViewGenerativeBehavior1.DefineFrontView 0#, 1#, 0#, 0#, 0#, 1#
drawingView1.X = 594.5
drawingView1.Y = 420.5
drawingView1.[Scale] = 1#
drawingViewGenerativeBehavior1.Update
drawingView1.Activate
End Sub
Please check the script and help me out.
Thanks in Advance.
Recording a macro is a very good way to get some code to start with.
Sadly,the code you get is usually missing some definition.
That's when you need to work with the other tools, the forum here is one of them but I would first try to get some info on the automation.chm file in your [catia]/code/bin folder.
The AxisSystem is missing, check the chm file to see how you can try to get this fixed...
Also, as you can see from the recording, DrawingViewGenerativeBehavior.DefineFrontView is used ... try to get some info from that in the chm file, it can help you get what you want.
Eric N.
Thanks, But I am new to VBA. I don't have that much knowledge of automation.chm and how to create a macro by reading that file.
will you please assist me.
i would suggest you find on youtube or on other platform some training on VBA...You dont need much, 5-10 hours of video + exercises would do, or ask your boss to get you a training.
Once you have a minimum of VBA & Object Oriented Programming understanding then we can start talking, this forum is more for CATIA problem (including CATIA VBA problem) than for VBA training...
Eric N.
