Vendor Recommendations Stepper Motor Components
jason2019
I currently have a 23frame size stepper motor with a ¼” shaft. I’m looking for vendors that deal in rubber coated cam followers or idlers for advancing material on the miniature side of things, 1.5" or less in diameter. Kind of like the components you would typically find in a printer. Mcmaster just doesn’t carry some of the smaller stuff. I need a rubber coated part on motor and then idler that would run tangent to motor's part.
Thanks!
Jason2019,
Does your stepper motor have a label that shows the manufacturer name? I would find the OEM name, look it up to and check their website. You can find the distributor in your area by checking their website. Good Luck!
