hi everybody
im working out in ventilation for a turbine room,whose temperature is 5*c greater than the ambient(32*c).is it ok to fix the turbine ventilators @15 AC
But you should add all other heat gains into the space such as:
. lights
. all other heat gain from other equipment in the space
. fan heat = kw/eff since fan & supply air would go to the space
. solar & transmission heat gain to the space
. people heat
You may want to add more cooling to improve the efficiency of the turbine.
