ANE91
- Mar 31, 2023
- 234
All,
I have a repair project located in a smaller city of Alabama. The building is a single-story retail structure with wood stud walls and pre-fab'd wood roof trusses. About 200 square feet of roof area is in need of attention following a tree impact. Before diving into any calculations or recommendations, I want to determine the governing building codes.
Per iccsafe.org ( the 2021 IBC and IEBC are in effect. However, the Code of Ordinances for the city lists the 2012 IBC and IEBC. I have not run into this conflict before. Does the state code supersede the city code? The other way around? Or does the newest code always govern?
I am not sure if I should be working with the city's building department (if they even have one) or the state's. Whether or not we will have to submit drawings–and what should be on those drawings–is my primary concern. I do still need to inspect to determine if Substantial Structural Damage applies.
Thank you.
Thank you.
