CivilTom
- Oct 13, 2012
- 41
Slightly worried about the vertical crack identified in the attached photo. The cracks widest point is .2 inches. My research suggested this may be due to temperature fluctuations since it is located in my boiler room and shouldn’t be of concern. But there’s also a drain line running perpendicular to the wall about 3’ away from the crack and now I’m thinking maybe there is a crack in the drain and water is displacing soil causing foundation settlement.
The 2 flat sits on a slab no basement. This block wall is the first floor.
