smokiibear
For light framed wood shear wall structures, is uplift required to be design with overstrength also? or only the compression? In figure c12.3-5, there is a note stating that anchorage is designed for standard load combinations.
How do you typically approach this?
Are there any other considerations and/or exclusions with regard to light frame wood shear walls for irregularities?
