Why is there a configuration of Vertical thermosiphon reboiler working with steam as heating medium in shell aide along with condensate pot with Level controller on the pot outlet which gets signal from reboiler condensate level and also condensate pot level?
why don't we use only steam trap rather than the condensate pot?
Also in the first configuration , when changing the feed rate to the column and increasing the steam flow , the reboiler frequently gets out of service?
