Vertical Turbine Fire Pumps - Canned Lineshaft or Sumps?
John_187
There is a remotely located fire pump to serve a building sprinkler system. A couple fire pump reps are saying either they are not aware of a canned lineshaft setup with their pump, or that it has to be in a 4 foot diameter sump.
I had another manufacturer do a vertical turbine pump that was not specifically for a fire protection system, and it came with a canned lineshaft.
So I was wondering if canned lineshafts were not allowed by the NFPA for fire pumps? Only could be used for domestic or irrigation?
Thanks for any input.
All fire pumps must be UL and/or Factory Mutual approved for use in the United States.
'Can pump' is a defined term in NFPA 20, so I don't believe they are necessarily prohibited. I've never heard of or seen one used as a fire pump, though.
What kind of water supply are you trying to pump from?
Thanks for the response.
It is pumping well water, which is stored in a tank. The tank is about 20 feet away from the vertical turbine pumps. The bottom of the sump or can, should be about 5 feet below the bottom of the tank.
